2022-09-07 09:46 AM
I am trying to repair a DELL H525AF-00 power supply that contains the CL2183 management IC. Could I get the datasheet for this IC?
2022-09-07 10:10 AM
A lot of data sheets aren't missing, but rather have limited distribution. This will be especially true of custom manufactured/designed parts where only the two parties involved will share any documentation or specifications.
You'll likely need to trace the circuit. Looks to have availability in Chinese markets
@Peter BENSCH
2022-09-07 10:10 AM
@Peter BENSCH
2022-09-08 12:48 AM
Thank you @Community member for bringing this to my attention. However, I can only add that CL2183 was discontinued a long time ago, but was also not generally available as it was a custom component of which only the client had some documentation.
Good luck!
/Peter
2022-09-09 10:42 AM
Perhaps data is available on Baidu data sheet sharing sites, or one of the vendors.
CL2183CN
