Other: hardware
EMIF02-USB03F2 D+/D- In Vs. Out?
If I leave all of the PullUp and PullDown pins disconnected does it matter if the USB Connector side data lines connect to D+/D- OUT while the Controller side data lines connect to D+/D- IN?This would be the opposite of what is shown in the datasheet...
Looking for ST9309 Transistor data sheet or equivalent
Hi, i'm looking for ST9309 - 137651 Transistor data sheet or equivalent. I beleive this transistor is obsoltet now so i'm searching for an equivalent transistor. This transistor is on my Bose accoustimass powered subwoofer. appreciate any help you ca...
RAnic by Associate
  • 312 Views
  • 0 replies
Resolved! Customizing web pages on the SPWF01SA
Hi,I'm using the STEVAL-3DP001V1 which has a SPWF01SA module on it. The default firmware of the module has some webpages already prepared for the 3D printing application. However I would like to customize these (or even make my own) webpages. In the ...
Kraal by Senior III
  • 535 Views
Doubt on the STM6600 use
Posted on February 16, 2017 at 23:54I want to use the STM6600 controller to manage the power ON/OFF of my microcontroller system. In the specific I want:- Turn ON the system simply pushing a button.- Turn OFF the system simply pushing the same butto...
