SPC560B40x how to get the programmers reference or what ever they call the long form documentation for these chips. This is not the power arch manual but the how to use the CAN controller ADC ect?
William craig
Posted on May 02, 2017 at 23:44
Erwan YVIN
Posted on May 03, 2017 at 09:32
Hello ,
You can use the RM associated to your device,
http://www.st.com/content/ccc/resource/technical/document/reference_manual/cf/ad/d5/76/55/1f/49/de/CD00192452.pdf/files/CD00192452.pdf/jcr:content/translations/en.CD00192452.pdf
Anyway , in SPC5Studio tool , there is some Test Application example (RLA & HAL)
you can import them.
             Best regards
                            Erwan
Erwan YVIN
Hello ,
             Best regards
                            Erwan
Posted on May 04, 2017 at 15:52
Thank you.
We are still in the component selection phase and are not yet using your
studio.. Your top level marketing website described the CAN buses as CAN-FD
(Higher transmission rates and 64 byte data possible) which is essential to
our design yet the Flex-CAN module described in the above manual only seems
to support CAN 2.0B with 8 byte data buffer limits. Am I missing something
or is the website in error. Do any of your processors support CAN-FD?
On Wed, May 3, 2017 at 2:33 AM, Erwan Y <st-microelectronics@jiveon.com>
Posted on May 05, 2017 at 11:40
Hello William ,
For CAN-FD (64 Bits), you should switch into SPC58 Family.
http://www.st.com/en/automotive-microcontrollers/spc5-mcus-for-interior-networking-and-low-power-applications.html?querycriteria=productId=SS1578
Please a look in SPC58 on
http://www.st.com
   Best Regards
                    Erwan
