How to find the reset source using MC_RGM register on SPC560C50L3 controller?
vishrut nair
Posted on February 17, 2018 at 17:21
Hello Everyone,
I am currently working on SPC560C50L3 controller with SPC5 studio. How do I differentiate between different resets for Eg. watchdog reset, power ON reset etc.
Through code I want the controller to identify the source of reset.
In the reference manual, they have mentioned RGM register (RGM.FES & RGM.DES), which will help the controller to identify the type of reset. But my question is, how to use this register?
I tried to read the RGM register in the start of my main function, but every time I was getting 0.
There must be some way to use this register to identify the cause of last reset.
Vishrut.
This discussion has been locked for participation. If you have a question, please start a new topic in order to ask your question
Erwan YVIN
Posted on February 19, 2018 at 16:06
Hello vishrut ,
i think that it is correct
Did you use a test application from SPC5Studio ?
if yes , we remove the status after each reset
 /* RGM errors clearing.*/
 RGM.FES.R = 0xFFFFU;
 RGM.DES.R = 0xFFFFU;�?�?�?
Best regards
Erwan
