Pasi MYLLYMAKI
Question from Predictive Maintenance Webinar 29th of April: Hello, in order to compute the ISO Velocity RMS, how can you remove the inclination of the MEMS from the raw aceeleration data using the DWB internal filters?
  • May 11, 2020
  • 1 reply
  • 701 views
    1 reply
    Vladimir JANOUSEK_34072
    Visitor II
    May 13, 2020
    It is possible to enable the internal IIS3DWB high pass filter (HPF), this option then removes the DC component of the acceleration - the earth gravity. In the webinar we mentioned MotionSP middleware (FP-IND-PREDMNT1), which outputs RMS speed directly but this SW needs to run on STM32.
