2020-12-07 3:49 AM - last edited on 2025-02-27 3:17 AM by Andrew Neil
Hi, i would like to know where exactly at the magnetic sensor (LSM303D) the magnetic field is measured.
We want to locate the exact position of magnet using multiple of these sensors, there for need to know where the value in the sensor is measured?
2020-12-14 8:00 AM
Hi @TScha.2 ,
I'll share you by private message the requested info, at least what I can disclose on this device.
If this info is valuable and useful for you, please select this answer as "Best".
-Eleon
2020-12-14 8:00 AM
Hi @TScha.2 ,
-Eleon
