MEMS (sensors)
Ask questions and find answers on ST MEMS sensors, such as the LSM6DSV and the LSM6DSL. Learn how to use the SensorTile.Box, and STEVAL kits.
LIS3DH HW or SW reset
Posted on October 14, 2016 at 09:14Hello, Is there a way to manually reset the LIS3DH? In our application, VCC is coming up *very* slowly, inherent to the system. I have the suspicion that the LIS3DH occasionally does not boot correctly as it fails ...
ngrunert by Associate
  • 1054 Views
  • 1 replies
IIS2DH configuration
Posted on October 19, 2016 at 10:31Hello, I have been playing with the IIS2DH configuration and there are couple of settings that are not clear for me, for example: - what is the I1_DRDY2 used for? - similarly I'm not sure about I1_AOI1 vs I1_AOI2 i...
imago by Associate
  • 1037 Views
  • 1 replies
LPS25HB reading
Posted on October 13, 2016 at 15:47HiI have 2 LPS25HB pressure sensors. I moved them from exact the same level to another level. The readings from both sensors are different. The start points are different and the slope of the value change is also d...
send MEMS data through usb
Posted on October 13, 2016 at 13:40Hi , I'm newbie with stm32f3 and i want to send the accelerometer data to my raspberry pi 2 through USB , please i need some help  ?
LIS331HH data resolution
Posted on October 11, 2016 at 21:34The datasheet specifies that it has 16 bit output data, but the data that i get out of the registers are 12 bit ie first 4 bits of High Byte is always 0. Am i doing something wrong here or is the effective resoluti...
koshy by Associate
  • 951 Views
  • 1 replies
LSM303AGR I2C
Posted on October 11, 2016 at 12:21I need connect 3 LSM303AGR in the same I2C bus. Is It possible? How do I change the I2C Address?   #lsm303agr #i2c
portatil by Associate
  • 1159 Views
  • 1 replies
LIS3DH ADC Specifications
Posted on October 30, 2013 at 03:02Are the specs for the ADC in the LIS3DH available?  I'm particularly interested in input voltage range, input current, and recommended capacitance for ADC inputs.
chris2 by Associate
  • 1525 Views
Is there a way to 'factory reset' the LIS3DH?
Posted on April 08, 2014 at 16:13Hi,Is there an easy way to 'factory reset' the LIS3DH?Does a simple power cycle do this?I looked through the data sheet and app note and could not see this defined there.Thanks #lis3dh-reset
dtroutt by Associate
  • 2167 Views
  • 4 replies
start with LIS2DH12 accelerometer programming
Posted on October 04, 2016 at 12:47Hi How can I start with LIS2DH12 accelerometer programming , is there any tutorial for beginners about the registers ,how they work and how to write a program for them  ? hanks for help #accelerometer-lis2dh12-c...
VL53L0X 2V8 mode
Posted on September 30, 2016 at 07:49Does anyone know how to change the standard mode to 2V8 mode?I could not find the details in the VL53L0X API manual. #vl53l0x
kondou-k by Associate
  • 1192 Views
  • 1 replies
