MEMS (sensors)
Ask questions and find answers on ST MEMS sensors, such as the LSM6DSV and the LSM6DSL. Learn how to use the SensorTile.Box, and STEVAL kits.
Resolved! ISM330DHCX Incorrect FIFO data / correct direct reading
[EDIT 03/04/25 09:15:35 AM] Well, it appears that, as usual, the real issue was sitting right in front of the keyboard… and could have been solved with a good old ‘Read The Freaking Manual.’ My deepest apologies for this classic case of user error! :...
Marconfr by Associate
  • 1552 Views
Resolved! Is it possible to use Sensortile.box Pro with Pi Pico W?
Would it be possible to connect and send sensor data to a Pi Pico W from the STEVAL-MKBOXPRO? I’m looking for a way to connect them together via Bluetooth but a wired connection would be alright too. I have connected a Pico to the sensortile box via ...
spi1 by Associate
  • 1034 Views
Is my ASM330LHH imu sensor spi code correct?
I want to read acc and gyro data from my ASM330LHH sensor with spi communication, but I can't try the code because I don't have a sensor at the moment, can you take a look at the code, is there anything wrong or missing?(I selected the SPI_CS pin as ...
x-cube-mems1 package SPI
I have ASM330LHH, LIS3MDL and LIS2DH12 mems sensors. I want to read data with spi communication using the x-cube-mems1 package. There are sample codes with I2C and bsp, but I don't know how to do this with spi. Can anyone help me to obtain roll pitch...
lis2dw12 linux driver difference
there are two kinds of linux driver for lis2dw12 in LIS2DW12 - 3轴MEMS加速度计,超低功耗,可配置单/双击识别,自由落体,唤醒,纵向/横向,6D/4D方向检测 - 意法半导体STMicroelectronics which is LinuxDriverIIO and LinuxDriverInput,1.what's the difference, which should we use, Do you have an appli...
xuehua by Associate
  • 1515 Views
  • 1 replies
Resolved! The differences between the IIS2DLPC and LIS2DW12
Could you tell me the differences between the IIS2DLPC and LIS2DW12?According to the reference URL, are there any differences between these two devices other than product longevity and guaranteed parameter values? I am particularly interested in whet...
MYabe.1 by Associate
  • 1054 Views
  • 1 replies
  • 2 kudos
Resolved! SensorTile.box PRO : Record human activity and pedometer
Hello, @Andrea VITALI,After using the WESU board (https://community.st.com/t5/mems-sensors/lsm6ds3-lis3mdl-calibration/td-p/762534)we decided to move forward with the sensor tile box PRO. We want to record human activity recognition and pedometer inf...
pierre63 by Associate II
  • 18256 Views
  • 11 replies
  • 2 kudos
Resolved! SPI NSS-Signal by Hardware, using IIS3DWB on an STM32L432 MCU
Hello!We are developing with the sensor IIS3DWB. I am able to interface it by spi like mentioned in st's github example, and I'm able to use st's platform independend c-drivers. It works fine, I get Acceleration, Temperature, device-ID...In that exam...
PR.4 by Associate II
  • 2733 Views
  • 3 replies
ASM330LHH gyro anti-pre-ADC aliasing filter
Hello, we are using the ASM330LHH in our product and are doing some bandwidth testing and trying to model the gyro channel behavior. Our settings are ODR = 6667Hz, LPF1 bandwidth = 470, LPF2 =3333Hz. Looking at the data sheet "Gyroscope filtering cha...
tjbh by Associate
  • 1922 Views
  • 3 replies
