Dear ST team, I am using STM VL53L1X distance sensor, and I have some problems with the VL53L1X satel. While the VL53L1X main part (the big sensor) is working perfectly, the VL53L1X satel stops measuring each time I move it.
ALe C.11
Please, do you know if there is a way to solve stability problems with the VL53L1X satel ?
Thank you for your help.
Best wishes
Anne
John E KVAM
That satel board and the I2C connection are really touchy.
I'm going to guess that if you have more than 6 or 8 inches of wire, you are going to run into this problem.
Try seperating the wire and twisting it. Or use thicker wire.
The right answer are stronger pull-ups, but that's a lot of work.
If this or any post solves your issue, please mark them as 'Accept as Solution' It really helps. And if you notice anything wrong do not hesitate to 'Report Inappropriate Content'. Someone will review it.
John E KVAM
