GNSS positioning
TESEO VIC3DA
Hi,I am new in TESEO VIC3DA. I have designed a board communication between MCU and TESEO VIC3DA.Does TESEO VIC3DA auto send NMEA sentences to my MCU through uart peripheral ? Thanks
Resolved! Teseo LIV4F output data rate configuration
Hi all,I have been doing some experimentation with a LIV4F module and am trying to configure the device for a 5Hz data output rate. I see the device supports up to 10Hz.The commands I have tried via teseo suite are:$PSTMSETPAR,1190,0.2 followed by $P...
AlexT by Associate II
  • 2250 Views
  • 4 replies
  • 3 kudos
Teseo-LIV4F
Hi team,    I already have this module-Teseo-LIV3F( https://estore.st.com/en/evb-liv3f-cpn.html ) But i need communicat the L5 band NAVIC signal. In this module not supported the L5 NAVIC signal.In this module-Teseo-LIV3F( https://estore.st.com/en/ev...
Aravind by Associate III
  • 2706 Views
  • 7 replies
  • 1 kudos
Firmware update for IRNSS,Teseo-LIV4F
Hi team ,     How to configer the firmware update for IRNSS and how to create a binary file.Firmware update which software is using?and any breakout board avaliable (Teseo-LIV4F) Thanks and regards Aravind
  • 769 Views
  • 1 replies
Resolved! Using A-GNSS to improve TTFF
Hello I am interested at looking at the Teseoo-LIV3F for a application but I require a very fast TTFF. Having read up on the A-GNSS option will this be available any where or any location in the world as long as the server is accessible ?So no matter...
TESEO-LIV4FTR
hi team,         Any breakout board avaliable for this module(TESEO-LIV4FTR) and sugess the antenna for this module. thanks and regards aravind.s.r
  • 954 Views
  • 0 replies
Sales and Tech support
i am from W-ibeda, which from shanghai.ASM330 which i used for automotive  IMU, now we have some issue and cannot solved, pls. assign sales and FAE to support. our distribute Future cannot support and won/t like to provide ST contact windows to us
