GNSS positioning
Ask questions and find answers on Teseo GNSS positioning solutions. Discuss NMEA sentences, SBAS activation, and signal troubleshooting.
Teseo-LIV3F, no satellite position.
Hello, Can you help me? I assembled a module on the Teseo-liv3f basis with a passive antenna (A25-4102920-AMT02). And I can not get the coordinates in nmea messages (screenshot in attach). What could be the problem? Thank you.
Sergei by Associate II
  • 9736 Views
  • 24 replies
Problem with X-Nucleo-GNSS1A1?
Hello.My name is aoki​​I am using Nucleo-F401RE and X-Nucleo-GNSS1A1.TESEO-SUITE is no longer displaying anything at all.I have tried the following to solve this problem.A. I initialized the flash of Nucleo-F401RE and downloaded the sample software, ...
ayasu.1 by Associate
  • 1034 Views
  • 1 replies
Date with 5.2.0 library
Hello,I'm trying to understand how to get simple information with the GNSS library and the example.I think I can find the time inside "pGNSSParser_Data->gpgga_data.utc" and position with "pGNSSParser_Data->gpgga_data.xyz" but is there an easy way to ...
Argail by Associate
  • 968 Views
STAGPS Testing fails to download the Rinex file
Hi,I am trying to test the COLD START behaviour of the X-NUCLEO-XGNSS1A1 and when trying to start the Autonomous mode I get the following response:Running Autonomous AGPS taskRinex files directory is D:\RINEXStart downloading file ftp://cddis.gsfc.na...
sougata by Associate II
  • 900 Views
Number of tracking channels available (Teseo -LIV3F)
Is there any information about the maximum number of tracking channels? Is it a pool of channels distributed between enabled gnss systems or does it exist a maximum number of channels available to a GNSS system? (In particular for Galileo) There are...
mads.l by Associate II
  • 851 Views
  • 1 replies
Teseo LIV3F Configuration over I2C Issue
I want to use the teseo LIV3f GNSS module as an I2C positioning sensor and i am following the AN5203. However, when i send the configuration over I2C, the GNSS module responds to all the commands with corresponding OK message except for the $PSTMSAVE...
VShen.1 by Associate
  • 779 Views
  • 0 replies
