Edge AI
Ask questions and find answers on how to deploy, debug, and optimize AI models on ST microcontrollers, microprocessors, and smart sensors.
ST seeks data scientists: Participate in a paid usability session
Hello ST Community members,   Are you a data scientist or machine learning engineer with experience deploying neural networks on edge or embedded devices? The ST team invites you to join a 45-minute remote usability session to provide technical feedb...
CUBE-MX AI stm32f446 problem compiling
Hi,I've joined introductory imbedded AI course on Udemy, unfortunately it is more than 4 years old using AI pack version 3.4.0 and I cannot get support from the instructor.Please find attached a presentation with screen shots of all steps used to gen...
ksale.1 by Senior
  • 3115 Views
  • 4 replies
The inputs for the ML stm32 ai
Hello everyoneI hope someone can help meI have an ML model that consists of 2 inputs as shown in the picture. Is the code for the inputs correct?   float ML_input[WINDOW_SIZE*NUM_POINTS]; float Diff_input[WINDOW_SIZE*NUM_POINTS - NUM_POINTS]; static ...
Aalna.1 by Associate II
  • 689 Views
  • 0 replies
Resolved! How to use CubeAI generated AI APIs in .c .h files
Hi,thereI'm a new learner and I'm trying to deploy an AI example given by ST official ,I trained the model using example dataset and generated an MDK file.I see there has some APIs for users to create and init neural net work like these:AI_API_ENTRYa...
Code Generator File structure of ver 9.00 AI Package
Hi,I'm following introductory course on Embedded AI, the course used Cube-Mx AI  3.4.0 AI Package, which generated a 'Data Processor .c' file. we need the file to insert user code for our application. But no where in the file structure in the up-to-d...
ksale.1 by Senior
  • 751 Views
  • 1 replies
Resolved! How to use NanoEdgeAI?
Hi all,Based on the tutorials, I am trying to create an AI lib using NanoEdgeAI.The lib seems created successfully, see attachment.But when I add it to the MDK project and compiler it, some errors like below is present:When I remove the libneai.a, th...
Junde by Senior III
  • 1259 Views
  • 3 replies
  • 2 kudos
Algobuilder GUI sensortilebox
Good morning everyone, I am trying to follow the example for machine learning given for the SensorTile Boxhttps://github.com/STMicroelectronics/STMems_Machine_Learning_Core/tree/master/configuration_examples/example_2_sensortilebox_algobuilder_unicow...
Frabbit_0-1716986655732.png Frabbit_1-1716986682155.png Frabbit_2-1716986782075.png
Frabbit by Associate III
  • 1109 Views
  • 1 replies
Resolved! nanoedge ai
so, i have been using nano edge ai since a long time. but now i cannot log the signals when i am trying to. will they be any reason for that. please, solve this.
suhfi by Senior
  • 3491 Views
  • 1 kudos
Lambda layer cannot be processed by CUBEAI
DearI have encountered some difficulties while using CUBEAI to analyze my self-trained object detection models.I trained my own dataset using the object detection models available in the STM32AIModelZoo. I have utilized the tiny_yolo, st_ssd_mobilene...
Carter by Associate II
  • 832 Views
  • 1 replies
