Why does the function void HAL_SYSTICK_Callback(void) never get called?
I'm using a Nucleo Board with a STM32F030 fitted.
I wanted to use the callback function mentioned above to clear an output that is set as part of a separate pin handling interrupt. I cannot find any material relating to needing to setup anything for the systick so I assume its running all the time and therefore the callbacks should be generated.
My code does not work however and when I debug, I find that that this callback function is never called. What am I doing wrong?
