Why CAN Bus (J1939) of STM32F405RGT is not working at vehicle's J1939 speed(250kbps) ?
i am making a J1939 data logger with STM32F405RGT. The vehicle's J1939 is transmitting data on 250kbps, but when i set250kbps in mcu it doesnot show any data on uart terminal , but when i set 500kbps in mcu then it shows some data on UART terminal.
I am using STM32CubeIDE and generated code using CubeMX. The Same firmware that has CAN configured at 250kbps receives data from a CAN Simulator.
