Use QSPI Nor Flash in MemoryMappedMode and FMC SDRAM at the same time
When i used a bootloader to make user program run from QSPI Nor Flash in MemoryMappedMode, it worked well.
But now i want to run user program from FMC SDRAM.
So firstly i plan to initialized both QSPI Nor Flash(MemoryMappedMode) and FMC SDRAM,
then copy program from QSPI Nor Flash to SDRAM with pointer.
But only a little part of data copied.
Does anybody know why?
