Nchun.1
TimeStamp1(Rising Edge) value is capturing as Zero always in ISR while Measuring Width of Pulse
  • April 18, 2021
  • 535 views
#include<NEW.h>
#include<stdio.h>
#include<stdarg.h>
void Ultra_setting();
void delay();
void Tim3_Capture();
void Uart1_config();
void delay1();
void uart_printf(const char *fmt, ...);
uint32_t timeStamp1 = 0,timeStamp2=0,width=0,Distance=0;
unsigned int flag=0;
void TIM3_IRQHandler()
  flag++;
  if (flag==1)
   timeStamp1=TIM3->CCR1;
   TIM3->CCER|=1<<1;/*Change to Falling Edge */
   uart_printf("%d\n", TIM3->CCR1);
  else
  timeStamp2=TIM3->CCR1;
  TIM3->CNT=0;
    if(timeStamp2>timeStamp1)
    width= timeStamp2-timeStamp1;
    else if(timeStamp2<timeStamp1)
      width= (0xffff - timeStamp1) + timeStamp2;
    Distance = width *(.034/2);
    flag=0;
    TIM3->CCER =1;//*Change to Rising Edge */
    WRITE(NVIC_ISER0 ,(0<<29));/*Disabling TIM3 Interrupt */
    TIM3->CR1=0;/*Disable Counter */
  uart_printf("The distance is %d %d %d %d\n", Distance, timeStamp1,timeStamp2,width);
int main()
  //GPIO A configuration
SystemInit();
Ultra_setting();
Gpio_Init();
Uart1_config();
  GPIOA->ODR =1<<8;/* Turning ON PA8pin */
  delay();/* 10 microseconds ON*/
  GPIOA->ODR =0<<8;/* Turning ON PA8 pin */
  Tim3_Capture();
  while(1);
void Gpio_Init()
  RCC->AHB1ENR |=1; /* Enabling clock for GPIOA port*/
  GPIOA->MODER |=2<<12;/*Alternative function in PA6 pORT*/
  GPIOA->AFR[0]|=2<<24; /* Alternate function low register is AF1 is TIM3_CH1 */
char buf[512];
int ret;
va_list args;
va_start(args, fmt);
ret = vsnprintf(buf, 512, fmt, args);
va_end(args);
if (ret > 0)
for (int i =0; i < ret; i++)
USART1->SR = 0;
USART1->DR = buf[i];
while(!(USART1->SR & (1<<6)) );
void Uart1_config()
RCC->APB2ENR |=USART1_CLK;
RCC->AHB1ENR |=1;
GPIOA->MODER |=2<<18;/* Enabling Mode of PA9 */
GPIOA->MODER |=2<<20;/*Enabling Mode of PA9 */
GPIOA->OSPEEDR |=3<<18;/* Enabling High speed of PA9*/
GPIOA->OSPEEDR |=3<<20;/* Enabling High speed of PA10*/
GPIOA->AFR[1] |=7<<4;/*Enabling AFR7 of PA9 */
  GPIOA->AFR[1] |=7<<8;/*Enabling AFR8 of PA10 */
USART1->CR1 |=USART1_EN;
  USART1->BRR =((3<<0) | (0x68<<4)); /*9600 Baud Rate*/
// USART1->CR1 |=USART1_PE;
// USART1->CR1 |=USART1_ODD;
USART1->CR1 |=USART1_RE;
USART1->CR1 |=USART1_TE;
void Tim3_Capture()
//input capture mode
  RCC->APB1ENR |= 2;   //ENABLE TIMER 3
  TIM3->PSC = 16;    //divide by 16
 //TIM3->CCMR1 |= (0b01<<0)|(0b0100<<4);
//  TIM3->CCMR1|=TIM2_CCIS;
  TIM3->CCER = 1;   //enable CH1 input capture
  WRITE(NVIC_ISER0 ,(1<<29));
  TIM3->EGR = 1<<1;
  TIM3->DIER =1<<1;
  TIM3->CR1 = 1; //enable TIM3
  // TIM3->CNT=0;
GPIOA->MODER |=1<<16;/*General Purpose output function in PA9 Port*/
GPIOA->OSPEEDR|=1<<16;/*Medium speed */
void delay()
 RCC->APB1ENR |=1<<0; /* TIM2 clock enabled*/
 TIM2->CNT=0;
 TIM2->ARR=70;
 TIM2->PSC=1;
 TIM2->CR1 |=1;
 while((!TIM2->SR & 1<<0));
 TIM2->SR=0;
waclawek.jan
Toggle a GPIO output pin when entering the TIM interrupt and observe on oscilloscope. You'll probably be surprised.
> TIM3->EGR = 1<<1;
This forces an interrupt.
And you don't clear the interrupt source in the ISR.
Nchun.1
Nchun.1Author
Sorry ,After Toggling pin i am not finding any difference after/begore disabling TIM3->EGR for below.
The timeStamp1 value is getting updated after the Disabling Event Generation Register
> TIM3->EGR = 1<<1;
#include<NEW.h>
#include<stdio.h>
#include<stdarg.h>
void delay();
void delay1();
void Gpio_Init();
  flag++;
  GPIOC->ODR =~(1<<8);/*Toggling PC8 pin */
  if (flag==1)
  else
   TIM3->CNT = 0;
    // uart_printf("The distance is %d %d %d %d\n", Distance, timeStamp1,timeStamp2,width);
    Distance =width * 0.34/2;
    flag=0;
int main()
   TIM3->CNT-0;
SystemInit();
Ultra_setting();
Gpio_Init();
Uart1_config();
  // while (1)
  Tim3_Capture();
while(1);
char buf[512];
int ret;
va_list args;
va_end(args);
if (ret > 0)
USART1->SR = 0;
void delay1()
TIM2->ARR=10000;
  TIM2->PSC=1999;
  TIM2->CR1 |=1;
TIM2->SR=0;
void Gpio_Init()
  RCC->AHB1ENR |=4; /* Enabling clock for GPIOC port*/
  GPIOC->MODER |=1<<16;/* Enabling general purpose output in PC8 Pin */
void Uart1_config()
RCC->AHB1ENR |=1;
void Tim3_Capture()
  TIM3->DIER =1<<1;
  // TIM3->EGR=1<<1;
  TIM3->CR1=1;
  TIM3->CNT=0;
void delay()
 TIM2->CNT=0;
 TIM2->ARR=98;
 TIM2->PSC=1;
 TIM2->CR1 |=1;
 TIM2->SR=0;
