Timer generate a delayed pulse with same width as input
Posted on August 02, 2017 at 20:25
Hi all, is it possible to use timer to capture the input pulse, and generate the output pulse with same width and a certain delay.
I have tried use one pulse mode with connect input on two channel, one trigger with rise edge and one with falling. but it did not work.
Thanks all for help!
