December 13, 2023
Stm32cube
  • December 13, 2023
  • 1 reply
  • 581 views
Hello, when I try to compile the code in the Stm32cubeide program, I see the error that the flash.ld file does not exist. And there is no file with flash.ld extension among my files. It is not created by stm32cubemx.
Peter BENSCH
Technical Moderator
December 13, 2023
Welcome @Ahmetcancol, to the community!
I am very sorry that this is happening to you. However, your information on this is quite sparse and so far we only know that the file is missing from your F1 project. It would at least make sense to upload the IOC file so that you can try to reproduce the problem.
In addition, the operating system and the versions of CubeMX and CubIDE you are using would also be useful to know.
/Peter
