anbeyon2
STM32, Keil MDK-ARM cannot debug, seems to try and run from SRAM
  • September 8, 2010
  • 1 reply
  • 609 views
Posted on September 08, 2010 at 15:27
    anbeyon2
    anbeyon2Author
    Posted on May 17, 2011 at 14:06
    Found out what the ptoblem is.
    We are using an external watchdog.  pPoduction fitted and alternative part.   If I disable the watchdog circuit I no longer have the problem.
    Interesting that it caused such odd things to happen especially in debug mode.
    The two parts spec looks more or less identical but there is clearly a difference.
    Thanks to all that read my message.
    Clive
