RTC runs slower 2 second / 5 minutes after disconnect power
We are using LSE 32,768. RTC looks like runs correctly if power is on. But if we disconnected power, RTC still hold data but run slower, about 2 seconds / 5 minutes.
We changed new battery, even used power supply to feed vbat pin, same issue.
I tried ST example on Nucleo STM32H743ZI too (enabled RTC_CLOCK_SOURCE_LSE), with / without removing SB156, same issue.
Thank for any suggestion.
