developer2
Senior
June 28, 2013
problem with USART bootloader programming STM32F407
  • June 28, 2013
  • 4 replies
  • 809 views
Posted on June 28, 2013 at 21:47
Hi all,
please could you help me to identify changes in communication using serial port and STM32 bootloader,
i'm able to program STM32F103 with version 2.2 chip ID 414 but i can't program STM32F407 with bootloader version 3.1 chip ID 413,
i'm getting NACK on command 0x73 - write unprotect  :(
what should i change to get ACK ?
there are no Flash or Read-out protections activated,
Kind regards,
    June 28, 2013
    Posted on June 28, 2013 at 22:11
    Does the boot loader report that it supports that command?
    Tips, Buy me a coffee, or three.. PayPal VenmoUp vote any posts that you find helpful, it shows what's working..
    developer2
    Senior
    June 28, 2013
    Posted on June 28, 2013 at 22:18
    well, i don't have any debug device, is there a way how to find it ?
    developer2
    Senior
    June 28, 2013
    Posted on June 28, 2013 at 22:54
    so i made some debugs and i found that command Write Unprotect is successful , but Init command 0x7f was executed too early after ACKs for WriteUnprotect,
    so i delayed the Init command and it's successful,
    but when send Erase command 0x43 i get ACK and after parameters 0xff 0x00 i get NACK ,
    developer2
    Senior
    June 29, 2013
    Posted on June 29, 2013 at 11:11
    solved .... i had to read ''small text'' in doc, Erase cmd is not supported in bootloader ver >=3.0, only extended erase,
    Thank You Clive1
    Kind regards,
