Problem Failed firmware Nucleo F411RE
Posted on August 20, 2015 at 11:25
Hi.
On board I found this file: FAIL.TXT - ''The interface firmware FAILED to reset/halt the target MCU''. The leds LD1 and LD3 of COM remain red. I tried to update firmware with . The update is successful with firmware V2J24M11, however, the LED remains red. Originally the firmware board is V2J22M5. What happened ? How can I restore the board?Thank you #v2j22m5 #f411re #swderror #nucleo #fail #f411re
