MSale.1
Senior
August 28, 2023
OV5640 Issue in JPEG mode
  • August 28, 2023
  • 1 reply
  • 1350 views
I try to use your OV5640 board with your OV5640 driver in STM32H747 BSP in JPEG mode.
The problem is that the FPS drop to 1 or 2 even at low resolution QVGA.
Can you show me what registers needed to be modified to make it work correct since your driver support JPEG but not working correct
REgards
M.Salem
KDJEM.1
Technical Moderator
September 6, 2023
Hello @MSale.1 ,
The DCMI needs to be configured to receive compressed data (JPEG) by setting the JPEG bit in DCMI_CR.
Please let me know if the issue is solved.
Thank you.
Kaouthar
