Posted on April 03, 2017 at 14:32The original post was too long to process during our migration. Please click on the attachment to read the original post.
I dont think you can sample the ADC that slow. If I am not wrong, the datasheet would tell you that you need to sample the ADCs faster than 50k sample rate.So you should probably set up the sampling faster but send your output to the UART only once every 250Hz if thats your application.
