migrating from Atollic to IAR
Posted on April 05, 2012 at 07:39
reasently i changed ide to iar and i getting strange problems: i have working code developed in atollic and tested on my discovery boards, but then i use same code on IAR, it just doesn't work. Like touchscreen code is completely non working, even were is no compile errors/warnings. all optimizations are set to no optimization, and i am using same library as in atollic, Any ideas how to fix that ?
