Jean DEMARTINI
LWIP cannot ping how to launch it
  • April 3, 2017
  • 1 reply
  • 605 views
Posted on April 03, 2017 at 15:54
LWIP used through STM32Cube, how to put ETH in action ?
    Technical Moderator
    April 3, 2017
    Posted on April 03, 2017 at 16:15
    Hi ,
    You can review the LwIP example available in the STM32CubeXX package to develop your application,
    as for STM32CubeF7: STM32Cube_FW_F7_V1.6.0\Projects\STM32756G_EVAL\Applications\LwIP
    For more details about LwIP, I suggest that you take a look to the following resources which can help you to go further in your application:
    - AN3966 : “LwIP TCP/IP stack demonstration for STM32F4x7 microcontrollers�
    - UM1713 : “Developing applications on STM32Cube with LwIP TCP/IP stack�
    It’s possible to use STM32CubeMX which allows generating initialization code and for more clarification you can follow this User manual
    http://www.st.com/content/ccc/resource/technical/document/user_manual/10/c5/1a/43/3a/70/43/7d/DM00104712.pdf/files/DM00104712.pdf/jcr:content/translations/en.DM00104712.pdf
    : paragraph 'B.3.6 LwIP' for the STM32CubeMX LwIP side.
    Imen
