inode
Is the bootloader permanent?
  • June 1, 2009
  • 3 replies
  • 1119 views
Posted on June 01, 2009 at 17:28
    16-32micros
    Posted on May 17, 2011 at 13:13
    Our UART Bootloader as described in AN2606 is permanent and is located in a ''ROM Area'' and can never be re-programmed by software or re-writed again.
    Cheers,
    STOne-32.
    inode
    inodeAuthor
    Is the serial bootloader in STM32 models permanent or is it just one time usable, in other words does your own firmware write it over?
    The reason I ask is that Luminary Micro calls ''one time bootloader'' as ''Serial Flash Loader'' and ''real'' bootloader as ''bootloder'' and I see serial flash loader mentioned in STM32 datasheets.
    inode
    inodeAuthor
    Great! Thank you.
