matthiasjunge9
INC /DEC
  • July 29, 2008
  • 712 views
Posted on July 29, 2008 at 11:24
INC /DEC
    matthiasjunge9
    Posted on May 17, 2011 at 12:40
    an expression like
    unsigned int i;
    i--;
    is compiled as
    LDR
    SUBS
    STR
    is there any sort of INC / DEC command to do this in one instruction on the ARM like on other processors?
    matt
    disirio
    SUBS is equivalent to a decrement instruction. LDR and STR are only required if your variable resides in memory and it is not allocated into a register.
    So: yes, it has increment/decrement instructions but it is not capable to increment/decrement variables in memory (like most other RISCs, it is a load/store machine).
    regards,
    Giovanni
    ChibiOS/RT
    http://chibios.sourceforge.net
