hukhongcongtu26111993
I Need Some Help To Understanding Timer Trigger....
  • May 10, 2016
  • 7 replies
  • 1076 views
Posted on May 10, 2016 at 11:41
Hi!
I want to use DAC generating Sine wave. But I don't understand why I need '' static'' key in the function
static void
TIM6_Config(
void
static
void
DAC1_Config(
void
);If I delete static, Sine wave do not creat. :( I need some explanation about static function and Timer trigger in STM32. this is my full code:
&sharpinclude <stm32f4xx.h>
&sharpdefine
OUT_FREQ 5000
Output waveform frequency
&sharpdefine
SINE_RES 128
Waveform resolution
&sharpdefine
DAC_DHR12R1_ADDR 0x40007408
DMA writes into this reg on every request
&sharpdefine
CNT_FREQ 42000000
TIM6 counter clock (prescaled APB1)
&sharpdefine
TIM_PERIOD ((CNT_FREQ)/((SINE_RES)*(OUT_FREQ)))
Autoreload reg value
const
uint16_t function[SINE_RES] = {
2048
2145
2242
2339
2435
2530
2624
2717
2808
2897
2984
3069
3151
3230
3307
3381
3451
3518
3581
3640
3696
3748
3795
3838
3877
3911
3941
3966
3986
4002
4013
4019
4020
4016
4008
3995
3977
3954
3926
3894
3858
3817
3772
3722
3669
3611
3550
3485
3416
3344
3269
3191
3110
3027
2941
2853
2763
2671
2578
2483
2387
2291
2194
2096
1999
1901
1804
1708
1612
1517
1424
1332
1242
1154
1068
985
904
826
751
679
610
545
484
426
373
323
278
237
201
169
141
118
100
87
79
75
76
82
93
109
129
154
184
218
257
300
347
399
455
514
577
644
714
788
865
944
1026
1111
1198
1287
1378
1471
1565
1660
1756
1853
1950
2047
static
void
TIM6_Config(
void
static
void
DAC1_Config(
void
int
main(){ GPIO_InitTypeDef gpio_A; RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE); RCC_APB1PeriphClockCmd(RCC_APB1Periph_DAC, ENABLE); RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA1, ENABLE); gpio_A.GPIO_Pin
GPIO_Pin_4; gpio_A.GPIO_Mode
GPIO_Mode_AN; gpio_A.GPIO_PuPd
GPIO_PuPd_NOPULL; GPIO_Init(GPIOA,
gpio_A); TIM6_Config(); DAC1_Config();
while
1
static
void
TIM6_Config(
void
){ TIM_TimeBaseInitTypeDef TIM6_TimeBase; RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM6, ENABLE); TIM_TimeBaseStructInit(
TIM6_TimeBase); TIM6_TimeBase.TIM_Period
(uint16_t)TIM_PERIOD; TIM6_TimeBase.TIM_Prescaler
0
; TIM6_TimeBase.TIM_ClockDivision
0
; TIM6_TimeBase.TIM_CounterMode
TIM_CounterMode_Up; TIM_TimeBaseInit(TIM6,
TIM6_TimeBase); TIM_SelectOutputTrigger(TIM6, TIM_TRGOSource_Update); TIM_Cmd(TIM6, ENABLE);}
static
void
DAC1_Config(
void
){ DAC_InitTypeDef DAC_INIT; DMA_InitTypeDef DMA_INIT; DAC_INIT.DAC_Trigger
DAC_Trigger_T6_TRGO; DAC_INIT.DAC_WaveGeneration
DAC_WaveGeneration_None; DAC_INIT.DAC_OutputBuffer
DAC_OutputBuffer_Enable; DAC_Init(DAC_Channel_1,
DAC_INIT); DMA_DeInit(DMA1_Stream5); DMA_INIT.DMA_Channel
DMA_Channel_7; DMA_INIT.DMA_PeripheralBaseAddr
(uint32_t)DAC_DHR12R1_ADDR; DMA_INIT.DMA_Memory0BaseAddr
= (uint32_t)&
function; DMA_INIT.DMA_DIR
DMA_DIR_MemoryToPeripheral; DMA_INIT.DMA_BufferSize
SINE_RES; DMA_INIT.DMA_PeripheralInc
DMA_PeripheralInc_Disable; DMA_INIT.DMA_MemoryInc
DMA_MemoryInc_Enable; DMA_INIT.DMA_PeripheralDataSize
DMA_PeripheralDataSize_HalfWord; DMA_INIT.DMA_MemoryDataSize
DMA_MemoryDataSize_HalfWord; DMA_INIT.DMA_Mode
DMA_Mode_Circular; DMA_INIT.DMA_Priority
DMA_Priority_High; DMA_INIT.DMA_FIFOMode
DMA_FIFOMode_Disable; DMA_INIT.DMA_FIFOThreshold
DMA_FIFOThreshold_HalfFull; DMA_INIT.DMA_MemoryBurst
DMA_MemoryBurst_Single; DMA_INIT.DMA_PeripheralBurst
DMA_PeripheralBurst_Single; DMA_Init(DMA1_Stream5,
DMA_INIT); DMA_Cmd(DMA1_Stream5, ENABLE); DAC_Cmd(DAC_Channel_1, ENABLE); DAC_DMACmd(DAC_Channel_1, ENABLE);}
#timer-trigger #static
May 10, 2016
Posted on May 10, 2016 at 12:55
The code as presented is nearly unreadable, please use the Format Code Block option. The Paintbrush [{}] icon.
The static directive shouldn't make.a difference to the functions in this context. What compiler are you using? Have you single stepped the code in a debugger to better understand what is going on.
Tips, Buy me a coffee, or three.. PayPal VenmoUp vote any posts that you find helpful, it shows what's working..
Posted on May 10, 2016 at 14:03
#include <
stm32f4xx.h
#define OUT_FREQ 5000 // Output waveform frequency
#define SINE_RES 128 // Waveform resolution
#define DAC_DHR12R1_ADDR 0x40007408 // DMA writes into this reg on every request
#define CNT_FREQ 42000000 // TIM6 counter clock (prescaled APB1)
#define TIM_PERIOD ((CNT_FREQ)/((SINE_RES)*(OUT_FREQ))) // Autoreload reg value
const uint16_t function[SINE_RES] = { 2048, 2145, 2242, 2339, 2435, 2530, 2624, 2717, 2808, 2897,
2984, 3069, 3151, 3230, 3307, 3381, 3451, 3518, 3581, 3640,
3696, 3748, 3795, 3838, 3877, 3911, 3941, 3966, 3986, 4002,
4013, 4019, 4020, 4016, 4008, 3995, 3977, 3954, 3926, 3894,
3858, 3817, 3772, 3722, 3669, 3611, 3550, 3485, 3416, 3344,
3269, 3191, 3110, 3027, 2941, 2853, 2763, 2671, 2578, 2483,
2387, 2291, 2194, 2096, 1999, 1901, 1804, 1708, 1612, 1517,
1424, 1332, 1242, 1154, 1068, 985, 904, 826, 751, 679,
610, 545, 484, 426, 373, 323, 278, 237, 201, 169,
141, 118, 100, 87, 79, 75, 76, 82, 93, 109,
129, 154, 184, 218, 257, 300, 347, 399, 455, 514,
577, 644, 714, 788, 865, 944, 1026, 1111, 1198, 1287,
1378, 1471, 1565, 1660, 1756, 1853, 1950, 2047 };
static void TIM6_Config(void);
static void DAC1_Config(void);
int main()
gpio_A.GPIO_Pin = GPIO_Pin_4;
gpio_A.GPIO_Mode = GPIO_Mode_AN;
gpio_A.GPIO_PuPd = GPIO_PuPd_NOPULL;
GPIO_Init(GPIOA, &gpio_A);
TIM6_Config();
DAC1_Config();
while (1)
TIM_TimeBaseStructInit(&TIM6_TimeBase);
TIM6_TimeBase.TIM_Period = (uint16_t)TIM_PERIOD;
TIM6_TimeBase.TIM_Prescaler = 0;
TIM6_TimeBase.TIM_ClockDivision = 0;
TIM6_TimeBase.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseInit(TIM6, &TIM6_TimeBase);
DAC_INIT.DAC_Trigger = DAC_Trigger_T6_TRGO;
DAC_INIT.DAC_WaveGeneration = DAC_WaveGeneration_None;
DAC_INIT.DAC_OutputBuffer = DAC_OutputBuffer_Enable;
DAC_Init(DAC_Channel_1, &DAC_INIT);
DMA_INIT.DMA_Channel = DMA_Channel_7;
DMA_INIT.DMA_PeripheralBaseAddr = (uint32_t)DAC_DHR12R1_ADDR;
DMA_INIT.DMA_Memory0BaseAddr = (uint32_t)&function;
DMA_INIT.DMA_DIR = DMA_DIR_MemoryToPeripheral;
DMA_INIT.DMA_BufferSize = SINE_RES;
DMA_INIT.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
DMA_INIT.DMA_MemoryInc = DMA_MemoryInc_Enable;
DMA_INIT.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
DMA_INIT.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
DMA_INIT.DMA_Mode = DMA_Mode_Circular;
DMA_INIT.DMA_Priority = DMA_Priority_High;
DMA_INIT.DMA_FIFOMode = DMA_FIFOMode_Disable;
DMA_INIT.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
DMA_INIT.DMA_MemoryBurst = DMA_MemoryBurst_Single;
DMA_INIT.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
DMA_Init(DMA1_Stream5, &DMA_INIT);
Sorry for my deficiency !!!
Posted on May 10, 2016 at 14:07
I use KielC v5.17. If I delete static directive , do not have sine wave on my oscilloscope.
May 10, 2016
Posted on May 10, 2016 at 14:43
Nothing is really jumping out, any linker errors?
Try this
#include <
stm32f4xx.h
int main()
GPIO_InitTypeDef gpio_A = { 0 };
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA | RCC_AHB1Periph_DMA1, ENABLE);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_DAC | RCC_APB1Periph_TIM6, ENABLE);
TIM6_Config();
DAC1_Config();
while(1)
TIM6_TimeBase.TIM_Period = (uint16_t)(TIM_PERIOD - 1); // 0 .. N-1
DAC_InitTypeDef DAC_INIT = { 0 };
DMA_InitTypeDef DMA_INIT = { 0 };
DMA_INIT.DMA_Memory0BaseAddr = (uint32_t)&function[0];
Posted on May 10, 2016 at 15:08
thanks for your suicide. I am going to test your code in tomorrow because i don't have any oscilloscope in my home.:).
Posted on May 11, 2016 at 04:19
I was test your code and the result is correct. I received sine wave on my oscilloscope. but I don't understand why I did wrong. Can you tell me abotut that?
Posted on May 11, 2016 at 04:40
And why I need to set first value for
