EAbra.3
I am designing hardware using STM32H7. I would like to connect three power monitor devices to SPI4 of MCU as slave devices, but SPI4 has only one NSS(slave select) pin. How should I connect these multi slave devices to SPI4 of MCU?
  • November 15, 2022
  • 3 replies
  • 813 views
LCE
Principal II
November 15, 2022
Use other GPIOs for NSS, pull them low before each SPI transaction, back to high again when done.
EAbra.3
EAbra.3Author
Thank you very much for the prompt reply. Can I use any of the I/O pins for NSS or is there any particular GPIO pins for the same?
EAbra.3
EAbra.3Author
I have one more question that, once I connected the GPIO pins as NSS, later I should control these pins using software. Am I right or not?
LCE
Principal II
November 16, 2022
Yes, you have to control these pins "manually":
GPIO LOW
do SPI stuff
GPIO HIGH
