NAham.1
How to retrieve STm32H757 MCU from SMPS power mode?
  • March 3, 2023
  • 3 replies
  • 920 views
I am using STM32H757 MCU on my custom board and was able to flash the code.
Once mistakenly I flashed without commenting the below lines in SystemClock_Config function
 HAL_PWREx_ConfigSupply(PWR_DIRECT_SMPS_SUPPLY);
__HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE2);
while(!__HAL_PWR_GET_FLAG(PWR_FLAG_VOSRDY)) {}
Till then I am unable to detect the MCU using ST debugger.
Tried with STM Utility & STM32CubeProgrammer to detect & flash
Tried various options like -
  1. Connect Under reset,
  2. PowerOn PCB and Click Connect at the same time
Nothing helps!
Any idea to overcome this issue
Thanks in Advance!
    March 3, 2023
    Strap BOOT0 HIGH cycle.power completely several times until.you can connect, then erase user code.​
    Tips, Buy me a coffee, or three.. PayPal VenmoUp vote any posts that you find helpful, it shows what's working..
    gbm
    Lead III
    March 3, 2023
    Set BOOT0 pin to 1, which will start the MCU in bootloader mode - then you may connect to it.
    My STM32 stuff on github - compact USB device stack and more: https://github.com/gbm-ii/gbmUSBdevice
    NAham.1
    NAham.1Author
    Thank you for your immediate response
    Just I tried by resetting the device and flashing using ULINK tool and able to flash the code
    Thank you once again!
