jrd
How to determine FLASH page size
  • May 7, 2010
  • 8 replies
  • 8609 views
Posted on May 07, 2010 at 22:40
    mcuisp2
    May 17, 2011
    Posted on May 17, 2011 at 13:50
    The Flash Size Infomation At 0x1ffff7e0 contain the KB size of Flash,
    if Flash>=128KB,then FLASH PAGE size is 2KB
    if not , page size is 1KB
    swhite2
    Unfortunately DBGMCU_IDCODE is not reliable on all devices.On some it is 0 out of reset.
    See the ''device limitations'' PDF's.
    e.g.
    ''Debug registers cannot be read by user software
    Description
    The DBGMCU_IDCODE and DBGMCU_CR debug registers are accessible only in debug mode (not accessible by the user software). When these registers are read in user mode, the returned value is 0x00.
    Workaround
    None.''
    May 17, 2011
    Try DBGMCU_IDCODE pg 1034
    http://www.st.com/stonline/products/literature/rm/13902.pdf
    The built in boot-loader also returns an ID code, and there is the RAM/FLASH size at the end of the boot loader memory.
    Tips, Buy me a coffee, or three.. PayPal VenmoUp vote any posts that you find helpful, it shows what's working..
    jrd
    jrdAuthor
    Trevor,
    I thought I'd be able to use that, but the ST web site shows Connectivity Line devices, such as the STM32F105V8, with 64K of FLASH.  PM0042 reads:
    ''The memory organization is based on a main memory block containing 32 pages of 1 Kbyte (for low-density devices), 128 pages of 1 Kbyte (for medium-density devices), 128 pages of 2 Kbyte (for connectivity line devices) or 256 pages of 2 Kbyte (for high-density devices), ...''
    I take from this that the Connectivity Line devices are available with as little as 64K of FLASH, but that the page size is still 2K.  This tells me that the memory size, in itself, does not imply a page size.
    ST has NOT done a good job documenting this.  It doesn't have to be this ambiguous!
    Justin
    trevor23
    As per last post I use this C code:
    #define FLASH_SIZE_IN_K_ADDRESS     0x1FFFF7E0
    PageSize = ((*(u16*)FLASH_SIZE_IN_K_ADDRESS) > 128) ? 2048 : 1024;
    infoinfo976
    May 17, 2011
    It tells you the 256KB version has 128 x 2KB pages, it makes no reference to your 64KB version. You would be better served looking in the ''Flash Loader Demonstrator'' application and it's MAP files, which does appear to confirm your belief that they all have 2KB pages.
    [Product]
    Name=STM32_Connectivity-line_64K
    FlashSize=0040     ;;ADDR_FLASH_SIZE=1FFFF7E0;
    RAMSize=0014       ;;ADDR_RAM_SIZE  =1FFFF7E2;
    PacketSize=FF
    ACKVAL=79
    MAPNAME=Pages
    PagesPerSector=2
    family = 1;
    [Page0]
    Name=Page0
    Index=00
    Address=08000000
    Size=00000800
    Type=111
    UFO=111
    [Product]
    Name=STM32_Connectivity-line_128K
    FlashSize=0080     ;;ADDR_FLASH_SIZE=1FFFF7E0;
    RAMSize=0020       ;;ADDR_RAM_SIZE  =1FFFF7E2;
    PacketSize=FF
    ACKVAL=79
    MAPNAME=Pages
    PagesPerSector=2
    family = 1;
    [Page0]
    Name=Page0
    Index=00
    Address=08000000
    Size=00000800
    Type=111
    UFO=111
    [Product]
    Name=STM32_Connectivity-line_256K
    FlashSize=0100     ;;ADDR_FLASH_SIZE=1FFFF7E0;
    RAMSize=0040       ;;ADDR_RAM_SIZE  =1FFFF7E2;
    PacketSize=FF
    ACKVAL=79
    MAPNAME=Pages
    PagesPerSector=2
    family = 1;
    [Page0]
    Name=Page0
    Index=00
    Address=08000000
    Size=00000800
    Type=111
    UFO=111
    jrd
    jrdAuthor
    James,
    That's what I originally thought, too, but I haven't found anything in the ST documentation that actually states this.  How did you learn this?
    Justin
