How to cancel transfer on OUT pipe of USB?
  • August 10, 2015
  • 3 replies
  • 949 views
Posted on August 10, 2015 at 10:14
Is there any way to cancel OUT transfer (receive) on STM32 using CubeF4 library?
I use USB in my device to communicate with PC (STM32 is ''device'', PC is ''host''). If client (PC side) program is ''crashed'' and my software protocol is not terminated correctly I have to send ''reset'' command to control (0) pipe of USB and handle it on STM32 side. The problem is that before the client application crashed last time, MCU firmware used USBD_LL_PrepareReceive function and device is waiting for data from PC!  I _have_ to cancel that transfer without resetting whole USB device stack. Is there any way to do that with CubeF4 library?
    August 10, 2015
    Posted on August 10, 2015 at 13:00
    OK, I got it   Edit: no, bad code!
    PCD_HandleTypeDef *hpcd =hUsbDevice.pData;
    USB_OTG_GlobalTypeDef *USBx = hpcd->Instance;
        USB_OTG_OUTEndpointTypeDef* outEp = GetOutEndpoint(&hUsbDevice, NDC_IF0_OUT_EP);
        USB_OTG_INEndpointTypeDef* inEp = GetInEndpoint(&hUsbDevice, NDC_IF0_IN_EP);
        //set global OUT NAK
        USBx->GINTMSK &= ~USB_OTG_GINTMSK_GONAKEFFM;
    if((USBx->GINTSTS & USB_OTG_GINTMSK_GONAKEFFM) == 0){
    USBx_DEVICE->DCTL |= USB_OTG_DCTL_SGONAK;
    while((USBx->GINTSTS & USB_OTG_GINTMSK_GONAKEFFM) == 0){}
    //begin disable EP
        USBx_DEVICE->DOEPMSK &= ~USB_OTG_DOEPMSK_EPDM; //Mask EP disabled interrupt for polling
    outEp->DOEPCTL |= USB_OTG_DOEPCTL_SNAK | USB_OTG_DOEPCTL_EPDIS; //Begin disable
    while((outEp->DOEPINT & USB_OTG_DOEPINT_EPDISD) == 0){} //Wait for disabled flag
    outEp->DOEPINT = USB_OTG_DOEPINT_EPDISD; //Clear endpoint disabled interrupt
    USBx_DEVICE->DOEPMSK |= USB_OTG_DOEPMSK_EPDM;//Unmask EP disabled interrupt
    USBD_LL_FlushEP(&hUsbDevice, NDC_IF0_OUT_EP); //Flush EP FIFO
    outEp->DOEPTSIZ = 0;
    USBx_DEVICE->DCTL |= USB_OTG_DCTL_CGONAK; //Disable global OUT NAK
    //Disable IN endpoint
    //stop tramsmission
    USBx_DEVICE->DIEPMSK &= ~USB_OTG_DIEPMSK_INEPNEM; //mask NAK effective interrupt
    inEp->DIEPCTL |= USB_OTG_DIEPCTL_SNAK;
    while((inEp->DIEPINT & USB_OTG_DIEPINT_INEPNE) == 0){} //wait 'till stopped
    //disable endpoint
    USBx_DEVICE->DIEPMSK &= ~USB_OTG_DIEPMSK_EPDM; //Mask EP disabled interrupt for polling
    inEp->DIEPCTL |= USB_OTG_DIEPCTL_SNAK | USB_OTG_DIEPCTL_EPDIS; //begin disable
    while((inEp->DIEPINT & USB_OTG_DIEPINT_EPDISD) == 0){}//wait for disable done
    inEp->DIEPINT = USB_OTG_DIEPINT_EPDISD; //Clear endpoint disabled interrupt
    USBx_DEVICE->DIEPMSK |= USB_OTG_DIEPMSK_EPDM; //unmask;
    USBD_LL_FlushEP(&hUsbDevice, NDC_IF0_IN_EP);
    inEp->DIEPTSIZ = 0;
    //unmask NAK EFFECTIVE interrupt
    USBx_DEVICE->DIEPMSK |= USB_OTG_DIEPMSK_INEPNEM;
    inEp->DIEPCTL |= USB_OTG_DIEPCTL_CNAK;
    while((inEp->DIEPCTL & USB_OTG_DIEPCTL_NAKSTS) != 0){}
    inEp->DIEPINT = USB_OTG_DIEPINT_INEPNE; //Clear NAK effective interrupt
    September 23, 2015
    Posted on September 23, 2015 at 16:45
    Code in my previous post is not working good if DMA mode enabled in USB.
    Here is correct version:
     portENTER_CRITICAL();
    PCD_HandleTypeDef *hpcd = (PCD_HandleTypeDef *)hUsbDevice.pData;
    USB_OTG_OUTEndpointTypeDef* outEp = USBx_OUTEP(hpcd->OUT_ep[NDC_IF0_OUT_EP & 0x7F].num);
    USB_OTG_INEndpointTypeDef* inEp = USBx_INEP(hpcd->IN_ep[NDC_IF0_IN_EP & 0x7F].num);
    //Disable OUT endpoint
    if((outEp->DOEPCTL & USB_OTG_DOEPCTL_EPENA) == USB_OTG_DOEPCTL_EPENA){
    //begin disable OUT EP
    USBx->GINTMSK |= USB_OTG_GINTMSK_GONAKEFFM;
    if ((inEp->DIEPCTL & USB_OTG_DIEPCTL_EPENA) == USB_OTG_DIEPCTL_EPENA){
    inEp->DIEPCTL |= (USB_OTG_DIEPCTL_EPDIS | USB_OTG_DIEPCTL_SNAK);
    inEp->DIEPTSIZ = 0;
    //can clear custom software  RX/TX buffers here
    portEXIT_CRITICAL();
    October 6, 2015
    Posted on October 06, 2015 at 20:43
    Update: small bugfixes in interrupts handling, now forking perfect in any tested conditions!
