Yli.8
How to add modified device tree with PWM control backlight
  • August 16, 2019
  • 744 views
My circuit board USES PE6 to control the backlight, but it cannot be adjusted. How to modify the device tree of TIM15_CH2.EV1 is not regulated.
EV1:
panel_backlight: panel-backlight {
compatible = "gpio-backlight";
gpios = <&gpiod 13 GPIO_ACTIVE_LOW>;
default-on;
status = "okay";
waclawek.jan
Which chip are you talking about?
Yli.8
Yli.8Author
I use stm32mp157aac, may I ask how to configure PWM control backlight
waclawek.jan
You should probably ask this question in a different forum https://community.st.com/s/topic/0TO0X0000003u2AWAQ/stm32-mpus
Yli.8
Yli.8Author
I think maybe I made a mistake
