Nmv1608
External interrupts
  • June 23, 2020
  • 3 replies
  • 1269 views
The line where the external interrupt is set  SYSCFG->EXTICR [2] |= (3 << 12); I want to set it for port D pin 10. How the masking and unmasking is done for port D?
waclawek.jan
Which STM32?
Nmv1608
Nmv1608Author
stm32l476 mcu
waclawek.jan
Bits 11:8 EXTI10[3:0]: EXTI 10 configuration bits
These bits are written by software to select the source input for the EXTI10 external
interrupt.
0000: PA[10] pin
0001: PB[10] pin
0010: PC[10] pin
0011: PD[10] pin
0100: PE[10] pin
0101: PF[10] pin
0110: PG[10] pin
so for PD10 you probably want
SYSCFG->EXTICR [2] |= (3 << 8);
Nmv1608
Nmv1608Author
Thank you for the answer.
