sara
double buffer
  • December 16, 2008
  • 1 reply
  • 419 views
Posted on December 16, 2008 at 13:43
double buffer
    sara
    saraAuthor
    Posted on May 17, 2011 at 12:56
    hi i want to ask about using double buffer instead of simple buffer ,using the example of usb mass storage found on the site, i changed the intialization of the endpoint in usb_prop.h,what should i do other than this??also are there any limitations on the addresses i chose for the buffers?
