ANajj.2
does the stm32 discovery board have an internal voltage regulator ?
  • May 8, 2021
  • 3 replies
  • 967 views
hello, i have a sensor that outputs a 10 volt and i want to read it's values with th stm32f303vc board wich it's analog pin voltage is about 3.3v so my sensor's output voltage need's to be regulated
May 8, 2021
You don't want a regulator, you probably need an OPAMP to get the sensor output into a usable range.
Or connect an external ADC with a broader input range.
Tips, Buy me a coffee, or three.. PayPal VenmoUp vote any posts that you find helpful, it shows what's working..
STM32 pins can read up to 3.3V on that board. You'll need a resistor divider to get the 0-10V output into the 0-3.3V range.
At least I think that's what you're asking. It's not really about a voltage regulator.
LMI2
Senior III
May 8, 2021
Voltage regulator is used as a power supply.
