mpmichal
DMA and timers problem
  • April 28, 2011
  • 5 replies
  • 1216 views
Posted on April 28, 2011 at 18:44
I wanted to learn how to ''connect'' DMA and timers, so I am thinking about such application. App will circularly copy data from buffer to timer. Timer is set in PWM mode and in my data buffer are numbers starting from 0 to 99 (those are pulse values). I have LED connected to PA8, and my code gives no errors, however it doesn't work. LED should shine and from time to time changes it's brightness, but nothing happens, it is off all the time. Could anybody help me with this? I also have empty NVIC_Configuration function because I don't really know what should be there. Here is my code:
&sharpinclude ''stm32f10x.h''
&sharpinclude ''STM32vldiscovery.h''
void RCC_Configuration(void);
void GPIO_Configuration(void) ;
void NVIC_Configuration(void) ;
void DMA_Configuration(void) ;
void TIM1_Configuration(void) ;
int i = 0;
u16 PWM_Buffer[100];
int main(void)
for(i=0 ; i < 100 ; i++) PWM_Buffer[i] = i;
RCC_Configuration();
GPIO_Configuration() ;
NVIC_Configuration() ;
DMA_Configuration();
TIM1_Configuration();
while(1);
// clock for GPIO
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_AFIO , ENABLE);
// clock for DMA
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
// clock for TIM1
RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);
GPIO_InitTypeDef GPIO_InitStructure ;
GPIO_Init(GPIOA, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin |= GPIO_Pin_8 ;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
DMA_DeInit(DMA1_Channel5);
DMA_InitTypeDef DMA_InitStructure ;
DMA_InitStructure.DMA_PeripheralBaseAddr = (u32)TIM1_BASE;
DMA_InitStructure.DMA_MemoryBaseAddr = (u32)PWM_Buffer;
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST;
DMA_InitStructure.DMA_BufferSize = 100;
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
DMA_InitStructure.DMA_Priority = DMA_Priority_High;
DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
DMA_Init(DMA1_Channel5, &DMA_InitStructure);
// turning DMA on
DMA_Cmd(DMA1_Channel5, ENABLE);
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure ;
TIM_TimeBaseStructure.TIM_Period = 99;
TIM_TimeBaseStructure.TIM_Prescaler = 99;
TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseStructure.TIM_RepetitionCounter = 150;
TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);
// channel 1 configuration
TIM_OCInitTypeDef TIM_OCInitStructure;
TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
TIM_OCInitStructure.TIM_Pulse = 50;
TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
TIM_OC1Init(TIM1, &TIM_OCInitStructure);
// ''connecting'' DMA and TIM1
TIM_DMACmd(TIM1, TIM_DMA_Update, ENABLE);
// turning on TIM1 and PWM outputs
TIM_Cmd(TIM1, ENABLE);
TIM_CtrlPWMOutputs(TIM1, ENABLE);
#dma-timers
April 28, 2011
Posted on April 28, 2011 at 23:00
If you want to alter the PWM ON from 0-99% it might help to program the right register in the timer. I might tinker some more, but this seemed to be pretty fatal on a quick review.
  DMA_InitStructure.DMA_PeripheralBaseAddr = (u32)TIM1_CCR1_Address;
Tips, Buy me a coffee, or three.. PayPal VenmoUp vote any posts that you find helpful, it shows what's working..
mpmichal
mpmichalAuthor
Posted on April 29, 2011 at 12:16
I am using Atollic True Studio and I don't have this defined:
TIM1_CCR1_Address
But I found that this is equal to: 0x40012C34 so I changed that line, but it still doesn't work.
April 29, 2011
Posted on April 29, 2011 at 18:23
With TIM1_CCR1_Address 0x40012C34
The PA.08 output is 2.4 KHz (from 24 MHz core), and the on duty cycle sweeps from 0 to 99%, repetitively. Stick a scope on it, and observe.
The LEDs built on the board are on PC.08 and PC.09
April 29, 2011
Posted on April 29, 2011 at 20:53
Here is a better example, using the on-board Blue PC.8 LED, and TIM3 CH3 with DMA1 Channel 3 shoveling PWM data on the TIM3 update (10 ms). This example uses a 10 KHz timer clock, a 100 Hz output frequency, with a 0-99% duty cycle phased over 1 second.
// PC.08, TIM3_CH3 (Remapped), DMA1 Channel 3
#define TIM3_CCR3_Address   0x4000043C
void TIM3_Configuration(void) ;
#define PWM_ELEMENTS 100
u16 PWM_Buffer[PWM_ELEMENTS];
int main(void)
    int i;
  for(i=0 ; i < PWM_ELEMENTS ; i++) PWM_Buffer[i] = i / (PWM_ELEMENTS / 100);
  TIM3_Configuration();
  while(1);
    // clock for GPIO (C, AFIO=REMAP)
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC | RCC_APB2Periph_AFIO , ENABLE);
    // clock for DMA
    // clock for TIM3
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
  GPIO_PinRemapConfig(GPIO_FullRemap_TIM3, ENABLE);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
    GPIO_Init(GPIOC, &GPIO_InitStructure);
    DMA_DeInit(DMA1_Channel3);
    DMA_InitStructure.DMA_PeripheralBaseAddr = (u32)TIM3_CCR3_Address;
    DMA_InitStructure.DMA_BufferSize = PWM_ELEMENTS;
    DMA_Init(DMA1_Channel3, &DMA_InitStructure);
    // turning DMA on
    DMA_Cmd(DMA1_Channel3, ENABLE);
    TIM_TimeBaseStructure.TIM_Period = 100-1; // 100 0..99    ON DUTY (100 Hz) Phases over 1 Second
    TIM_TimeBaseStructure.TIM_Prescaler = 2400-1;    // 24 MHz div 2400 (10 KHz tick)
    TIM_TimeBaseStructure.TIM_RepetitionCounter = 1;
    TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
    // channel 3 configuration (PC.08) Remapped
    TIM_OC3Init(TIM3, &TIM_OCInitStructure);
    // ''connecting'' DMA and TIM3
    TIM_DMACmd(TIM3, TIM_DMA_Update, ENABLE);
    // turning on TIM3 and PWM outputs
    TIM_Cmd(TIM3, ENABLE);
    TIM_CtrlPWMOutputs(TIM3, ENABLE);
mpmichal
mpmichalAuthor
Posted on April 30, 2011 at 11:18
Thank you very much! That solves my problem.
