Difference in programing STM32L562 and STM32H735 MCU
Hello, In my project I need to have MCU that can handle lot's of data and be power efficient when I need to.
In first, i was running STM32L562, but it looks like I will need tones more performance to complete many tasks in time.
I use DMA alot, for sending and receiving data so I don't have to waste time for manually writing to data register ( I will be running 3 UARTS with AT commands, GPS, Bluetooth, GSM module) On top of that i need CANBUS decoding that is running 0.5Mbps and is nearly saturated with messages, so tones interrupts as well as other things.
I found that STM32H735ZGT6 Is nearly the same price, but has at least 6x performance compared to STM32L5 (Cortex M33 running at 110MHz vs Cortex A7 Running at 550MHz)
What will be difference running this MCU in terms of DMA, I never had any real work with DMA on this chip, I see many questions of DMA not working, cache alignment and invalidation. And also placing data for DMA into correct memory location.
Any advice ? How much different coding will be compared to L5 part
Thank you for any thoughts
