CubeMX SD Card usage
Posted on March 27, 2015 at 13:34
Has anybody used the CubeMx SD Card generated code?
I tried but could not use it, I assume my init code is not correct (or that cube code is useless).On the same board, I have USB host with FATFS working, I need to be able to use SD card as well.If you got this working, please help.Thanks #i-can''t-help-you-with-that
