Can I use usart2 DMA for RX and TX at the same time ?
Posted on March 17, 2014 at 23:01
Previously I was using usart2 dma TX and had an int and isr that would handle the RX data.
Can I have the dma enabled for both tx and rx for usart 2 ? It seems weird them both pointing at the same DR ? I've figured out the streams to use and about to start test/modifying, just wanted to check that what I'm doing is possible. Thanks
