LPlyu.1
4bit SDIO not working, but 1bit SDIO working fine.
  • March 15, 2021
  • 3 replies
  • 1392 views
I use CMSIS to write program that transfer data from SD card through SDIO. For my task i need 4bit mode, but it isn't working. When i try to read some block from SD card STBITERR bit in SDIO_STA register goes high, that means that start bit hasn't been detected on all data lines. But when i use 1bit mode all works fine.
MCU: STM32F407VGT6
How to fix this problem?
March 15, 2021
Check wiring, socket and pull ups.
Show parts and circuit
Try other known working examples.​
Tips, Buy me a coffee, or three.. PayPal VenmoUp vote any posts that you find helpful, it shows what's working..
LPlyu.1
LPlyu.1Author
I am using devebox board, it has soldered socket, so wiring is not a problem.
I use internal pull-ups that should work. And i tried some other working examples, but it didnt work too.
trave.1
have you resolve your problems?
