JJimm
STM32_AcousticEC_Library is not working with STM32F746 (build with IAR)
  • July 26, 2019
  • 1192 views
I am working on STM32F746.
I am facing problem with Echo Cancellation lib, I refered fd-aud-smartmic1
uint32_t EC_Init(void)
 EchoHandlerInstance.tail_length= 512;
 EchoHandlerInstance.preprocess_init = ACOUSTIC_EC_PREPROCESS_ENABLE;
 EchoHandlerInstance.ptr_primary_channels=1;
 EchoHandlerInstance.ptr_reference_channels=1;
 EchoHandlerInstance.ptr_output_channels=1;
 AcousticEC_getMemorySize(&EchoHandlerInstance);
 EchoHandlerInstance.pInternalMemory = (uint32_t *)malloc(EchoHandlerInstance.internal_memory_size);
 if(EchoHandlerInstance.pInternalMemory == NULL)
  while(1); /*Error Management*/
 error_value = AcousticEC_Init((AcousticEC_Handler_t *)&EchoHandlerInstance);
 if(error_value != 0)
 EchoConfigInstance.preprocess_state =ACOUSTIC_EC_PREPROCESS_ENABLE;
 EchoConfigInstance.AGC_value =0;
 EchoConfigInstance.noise_suppress_default = -15;   /* Default: -15 */
 EchoConfigInstance.echo_suppress_default = -40;    /* Default: -40 */
 EchoConfigInstance.echo_suppress_active = -15;    /* Default: -15 */
 EchoConfigInstance.residual_echo_remove = 1;     /* Default: 1  */
 error_value = AcousticEC_setConfig((AcousticEC_Handler_t *)&EchoHandlerInstance, (AcousticEC_Config_t *) &EchoConfigInstance);
 //Internals.AudioOutRdPtr = 0;
 return error_value;
1> If I use __CRC_CLK_ENABLE() before EC_Init, sw is stucked here:
I try to extand heap but not work
2> If I do not use __CRC_CLK_ENABLE() before EC_Init, sw is stucked after AcousticEC_Init : return value ACOUSTIC_LOCK_ERROR
Do you have any idea?
Thank You
July 26, 2019
Look at how much memory it is requesting, and why your malloc() isn't providing that.
printf("Requesting %d\n", EchoHandlerInstance.internal_memory_size));
If malloc() returns a NULL, then clearly not sufficiently. Review where the heap is situated, and why the allocator fails at it's task. For GNU/GCC likely an issue with __sbrk()
Tips, Buy me a coffee, or three.. PayPal VenmoUp vote any posts that you find helpful, it shows what's working..
JJimm
JJimmAuthor
 EchoHandlerInstance.internal_memory_size is 53988. Something wrong with AcousticEC? The filterlength setting is 512 only.
July 27, 2019
Make sure to zero out EchoHandlerInstance
You have that much memory, humour it, I don't know what the overhead/requirements are.
JJimm
JJimmAuthor
Thank You for your answering.
I am going to implement EC by myself rather than working on bug lib.
Many times I faced problem with audio Lib from ST. They should open the source for community or no one will use their Lib.
