c239955_stm1
ST6 Programming
  • October 1, 2003
  • 798 views
Posted on October 01, 2003 at 14:30
ST6 Programming
c239955_stm1
Posted on October 01, 2003 at 12:45
Hi all,
I got the ST6230 Starter Kit and I tried to use the IDE from Raisonance;
When I try to compile the following program, I got, per every line the error:
150 UNKNOWN MNEMONIC (see second file )
Do you know where I’m wrong?
Thank you
________________
Attachments :
TEST_error.txt : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I0Iv&d=%2Fa%2F0X0000000bWz%2F.Sv_R_r6pBmnq9lYJh3JTb_Xl7fEml3.AUzyKqV6wbY&asPdf=false
Test.asm : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I0GW&d=%2Fa%2F0X0000000bX1%2Fi_ixuu1o8atK9QxkmptHFHPpCGZOpxHA2uksVl6GL.Y&asPdf=false
sjo
You are getting this error because the file you are assembling is in the old ST syntax.
You have two choices, set the ''Use AST6 Syntax'' in the assembler options or the better way would be to convert your project to the newer syntax, have a look at the examples given with RIDE.
I would recommend converting your project to the newer syntax.
sjo
