dmunari9
Issue with X-flash writing.
  • November 18, 2003
  • 3 replies
  • 840 views
Posted on November 18, 2003 at 08:18
dmunari9
dmunari9Author
Posted on November 18, 2003 at 04:07
Hello ST7 users.
I am sure someone will be able to help me.
Last time Katrin was very helpful.
I have debugged an ST7LITE1 with INdart emulator and I have successfuly written some data into x flash memory to be stored.
I have programmed an mcu to make it run alone in my target borad and (surprise) it doesn't write the flash anymore.
I have checked many things (option bytes, clock, ecc.) everything seems ok.
Anyone ?
jatin
November 18, 2003
Posted on November 18, 2003 at 04:45
Please check if the clock source selected in the option bytes is same as in the target board?
dmunari9
dmunari9Author
Hi Jatin, thanks for you interest.
The inDART uses a clock on PB4.
When the application runs alone, I have set the RC OSCILLATOR
I copy here the part of the program which writes the flash.
Greetings from Italy.
XF_PROG MACRO ADDR,DATA
LOCAL Copy_01
LOCAL Copy_ex
sim
clr X
Copy_01:
ld A,(X_code,X)
ld (XProg,X),A
cp X,#$10
jreq Copy_ex
inc X
jp Copy_01
Copy_ex:
ld A,#ADDR.h
ld CURRENTH,A
ld A,#ADDR.l
ld CURRENTL,A
ld A,DATA
ld XDATA,A
call XProg
rim
MEND
; Program entry
WORDS
segment 'X_rom'
; I valori sono inizializzati a #$ff
; Tempi di attesa
.X_WAITVEL1 DC.B $ff
.X_WAITVEL2 DC.B $ff
.X_WAITVEL3 DC.B $ff
; Periodo odometro
.X_VELTH3H DC.B $ff
.X_VELTH3L DC.B $ff
.X_VELTH2H DC.B $ff
.X_VELTH2L DC.B $ff
.X_VELTH1H DC.B $ff
.X_VELTH1L DC.B $ff
; Soglie abilitate disabilitate
.X_ENABLETH DC.B $ff ;$00
; Flag velocita'
.X_SFVEL DC.B $ff
WORDS
segment 'rom'
X_code:
bset FCSR,#1
ld A,XDATA
ld [CURRENTH.w],A
bset FCSR,#0
xLoop: btjt FCSR,#0,xLoop
ret
