jm_it
External Memory
  • March 11, 2004
  • 4 replies
  • 801 views
Posted on March 11, 2004 at 06:29
External Memory
jm_it
jm_itAuthor
Posted on March 02, 2004 at 08:46
I work on ST10F168 and i use external ram by EBC in 16 bits demux mode.
There are 4 Chip Select available for ram : CS1,CS2,CS3,CS4
and 23 adress bits : A1->A23
So, there are (2^23 * 4) bytes accessible <=> 32Mo
I would to know if i am right and if i can declare an external memory map of 32 Mo !
Thanks for any suggestions !
Regards,
Jim
charles239955_st
March 2, 2004
Posted on March 02, 2004 at 10:23
Hello Jim,
Unfortunatly the ST10 address range is limited to 16Mo (internal Flash included) because we only use 24 bit to create the total absolute address.
Bye
jm_it
jm_itAuthor
Posted on March 08, 2004 at 09:35
Ok but 16*8bits or 16M*16bits ?
charles239955_st
March 11, 2004
16M*8bits
