gsilvestri
equate info
  • March 10, 2004
  • 4 replies
  • 970 views
Posted on March 10, 2004 at 10:39
equate info
gsilvestri
Posted on March 10, 2004 at 08:17
Hello
I current use an ST72334 uC.
I have a problem in my code as follow
lab_A equ 3
lab_B equ 2*lab_A+1
during the compilation it stated out the following error message:
Error 67: Improper Character(s) '+1'
Can I use this expression for equate?
I should like to update some parameters depending to another one.
Bye
jatin
March 10, 2004
Posted on March 10, 2004 at 09:43
Try it using like:
.lab_A equ 3
.lab_B equ 2*lab_A
.lab_C equ {lab_B+1}
gsilvestri
Posted on March 10, 2004 at 10:00
thank you, now it run!
Do you know a manual ( or an Application Note) where I can found some trick and/or use about this assembler directive?
Bye
jatin
March 10, 2004
Yes, you can download ''ST7 Assembler-Linker User Manual'' .
